02-22-2023 12:04 PM
Each week I produce a multipage bulletin. I print the two sided cover in color as one print job, then the insides of the bulletin (2 pages, double sided, black and white) separately.
My previous copier, I could print the 80 cover pages, then put those pages in the bypass tray and when I printed the "insides" of the bulletin, I could set up the print job (in the printer profile menu) to "insert front cover". It would grab a cover from the bypass tray, pull it through the machine, then the inside pages of the bulletin would print. That way I had a stack of bulletins waiting for me to separate and fold in half.
I just got my c357if. I was told I would be able to insert a cover page from bypass tray into a print job.
For the life of me, I can not figure out if that is actually an option. Is that possible?
02-22-2023 12:13 PM
Hi, vbcoffice!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
