imageRUNNER ADVANCE 6255 Trouble with EFax setup
NCbanjopicker
I'm trying set up Efax on this Canon Imagerunner Advance 6255 copier and I'm not having much luck. Our phone/fax line is down and we don't know when it will be repaired. I read that the printer is capable of using I-Fax so figured since we already have Efax it might work. I changed the fax number in the machine to the efax number. It is already set up for scan to email and that works. I tried a couple different ways to send an efax, using just the efax phone number and it just beeps and says specify destinations? So I tried adding @efaxsend.com to the fax number same thing? I'm missing something somewhere just cant figure it out.
5 REPLIES 5
Moderator
Moderator
Thanks for joining the conversation, NCbanjopicker!
While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
Already talked to our dealer they didn't have an answer or weren't sure exactly how to set it up.
Find another dealer.  The set up for iFAX is standard.
Mail provider
SMTP or POP server address
Username
Password
Port
Encryption type
NCbanjopicker
I think we decided to ditch canon
Having supported a countless number of brands for years, I can tell you that all of them use a similar configuration.  This technology is standard across the industry .  Canon is no different that other manufacturers
Friends and Family
