Canon TM-200 Error EC21-2F53 – Printhead Issue?
Lethan
Hello,
I'm experiencing a printhead-related issue with my Canon TM-200 printer. The printer displays the error code EC21-2F53, which seems to indicate a problem with the printhead voltage (VH).
Troubleshooting Steps Taken:
✔️ I removed the faulty printhead from my TM-200 and installed it into another, fully functional TM-200 printer. The second printer also failed to recognize the printhead, showing a similar error.
✔️ I then installed a working printhead from the second printer into the one that originally had the error. It was detected without any issues, confirming that the printer itself is working fine.
✔️ I cleaned the printhead contacts (but not with water) and tried reinstalling it, but the error persists.
Conclusion:
Since the working printhead is recognized in both printers and the faulty one is not, it seems that the printhead itself is damaged.
Questions:
  1. Is there any known method to reset or repair a faulty printhead, or is replacement the only option?
  2. Could a firmware update cause this issue?
  3. Is this a common problem with Canon TM-200 printheads?
I would appreciate any advice or recommendations. Thanks in advance!
3 REPLIES 3
Sonya1
Hi Lethan,
The print head warranty is separate from the printer's warranty. The print head has a one year or 10 trillion droplets, whichever comes first. Updating your imagePROGRAF TM-200's firmware will not cause a print head error. Once the error code EC21-2F53 is displayed, the only option is to replace the print head. To determine if your print head is under warranty, please contact us at 1-800-423-2366 (press option 1 then option 3 for Large Format Printers), Monday through Friday from 8:00 AM to 6:00 PM EST, excluding holidays. I hope this is helpful.
SuppliesMaster
Hello sonya,
I have a PF 06 head mounted on the shopping cart, but I can't see the description of the warranty you mention.  Could you tell me where I see this guarantee before I buy Please?
Hi, SuppliesMaster!
Sonya was referring to the printhead that comes with the unit from the factory.
For questions relating to a new order, please get in touch with our sales team directly at 1-800-385-2155 or by chat (during normal business hours) at https://canon.us/contact-us
