03-13-2024 06:33 PM
Windows 11 computer still prints fine. All windows 10 computers show offline. The printer is visible in the router settings. Wasted too many hours resetting and troubleshooting. If I delete the printer, it cant be found again? Honestly its a deal breaker for me. I have recommended and installed hundreds of canon printers. Will there be a fix for the drivers? Will I wait for it? Will I ever buy or suggest to my customers that they buy canon? If anyone has a fix that does not include the general home user troubleshooting, I am all ears.
03-13-2024 08:58 PM - edited 03-13-2024 09:01 PM
Greetings ,
This fix does not involve general home user troubleshooting.
You indicated the printer is connected to your wireless network and your Windows 11 computer is printing.
Login to the routers admin portal and reserve the IP address the router has assigned to the printer.
Now confirm you can ping the printer using its IP address from a command prompt on one of the Windows 10 PC's.
Next, remove the printer from any Windows 10 PC that is not able to connect currently. Then restart the system.
Now connect the printer as a TCP IP device using its IP address. This is in control panel device and printers. Use the add button at the top of the applet. Select the line at the bottom. I do not see the printer I want to add and then select the TCP/IP address radio button. Now enter the IP address you reserved previously.
All of this is contingent upon you being able to ping the IP address of the printer from a command prompt successfully. Once that communication is verified, you'll be able to add the printer by its IP address.
Greetings ,
03-15-2024 04:44 PM
Thank you for the quick response,
The solution was reserving the IP address in the router. The Ubiquity DM pro has no shortage of settings.
I'm still not sure when the change happened, everything was printing fine not that long ago. My grand daughter pressed the print button over 100 times before she asked me why it's not printing.
03-15-2024 05:25 PM
Glad it helped 🙂
Ubiquiti APs are tricky at times. They have another feature that I don't recall what Ubiquiti calls it that allows you to associate an endpoint with a particular AP on the network. Devices can still seamlessly roam, but it lets you associate persistent devices (like a printer) to one AP (example the closest) for best possible connectivity. The good news is now that you have a reserved addressed, the printer will always be discoverable at its static destination. Have a great weekend!
