08-29-2023
01:04 PM
08:55 AM
We installed the printer driver on Windows 10 x64 device, the printer works but when we start the scan software scan utility it keeps saying "A scanner driver supporting this software is not installed. Install it and try again." . We tried multiple time reinstall and reboot, but nothing works.
06-19-2024 02:55 AM
I have been having the same problem for months and have GIVEN up, after spending hundreds of $$ on genuine canon printer ink, I cant use the scanner!!
1. "Could not install the scanner driver. Try to install again." x 10000
followed when I run the MF utility:
2. "A scanner driver supporting this software is not installed. Install it and try again". - SEE #1 !@#$$
HELP!
06-19-2024 10:33 AM - edited 06-19-2024 10:35 AM
This is a duplicate post, so I have replied to your thread:
ImageClass MF743Cdw - Cannot install the scanner! ... - Canon Community
06-27-2026 08:14 PM
I have been reading a few posts referencing this far-too-common problem of the MF 743 machine not scanning. A client moved his MF743 to a new location, new network, etc. After the move, neither the printing nor scanning features worked. I soon remedied the printing issues. However, I cannot get the machine to scan. It is pretty clear what is going on -- the only source for a scanner driver appears to be the software on the Canon website, [Windows 64bit] MF743Cdw/MF741Cdw MFDrivers (Generic Plus UFR II / Generic FAX / ScanGear) from 2025. The printer & fax drivers install, but the scanner driver fails to install -- at least, that is what the software installer states is the issue. After running the installer software when I look in Device Manager the scanner is listed there and it apparently has a driver. I have installed the [Windows 32bit & 64bit] MF Scan Utility Ver.1.21.0.2, however, the scan utility tells me that the scanner is not installed, which is not terribly surprising since the MF 743 installer software told me the same thing.
The OS is Windows 10 Pro. The only antivirus software is the Windows one. I tried installing it once with the firewall completely turned off -- it made no difference. I have removed all of the instances of the scanner from the Device Manager, restarted the computer and attempted the installation again. Same results. Are there any workable solutions to this problem?
06-27-2026 11:12 PM - edited 06-27-2026 11:16 PM
Greetings @phoenixvoice,
I have seen hundreds of these installations. Failures are not common. It happens occasionally and it's usually explainable. Typically related to something in the user's software environment.
There's a solution for this. It's not difficult. I don't have a Windows 10 VM handy so I'll provide the steps in a little bit.
06-27-2026 11:49 PM - edited 06-27-2026 11:52 PM
Doing this from memory. I don't use windows 10 any longer.
Open device manager, expand the Imaging devices heading.
Select the first entry for the scanner. You may have more that one.
Right click and select update driver.
Then select Browse My Computer... then Let Me Pick....When the new window opens, ensure the show compatible hardware box is checked.
Select the first entry and click Next. The drivers should update. Once complete, close the dialog. Now right click on the scanner entry you just updated and select disable. << This is an important step. Then restart the system.
In the past, this enabled the scanner driver. Much has changed with windows 10 subsequently. If this doesn't work, try pointing the driver update to the install directory where the latest Canon drivers were installed.
Let me know if this helps.
06-28-2026 01:30 AM
Thank you for the quick response! I have access to this system remotely, so I will try these steps tomorrow morning and let you know what happens.
