06-19-2024 02:58 AM
I have been having this problem for months (years?) and have GIVEN up, after spending hundreds of $$ on genuine canon printer ink, I cant use the scanner!!
1. "Could not install the scanner driver. Try to install again." x 10000
followed when I run the MF utility:
2. "A scanner driver supporting this software is not installed. Install it and try again". - SEE #1 !@#$$
HELP!
06-19-2024 10:34 AM
I'm sorry you are frustrated. I'm not following your post. You have not told us what OS version and build you are using the printer with?
What software did you try to install? What failed or didn't work?
For windows, install this:
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDIwMDAwNjg2NTAz&cmp=ABR&lang=EN
For MAC:
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDEwMDAxMjI1ODAx&cmp=ABR&lang=EN
If the application does not install, we will need to know what the result is, Error message? , Etc.
06-19-2024 06:26 PM
Hello and my apologies;
OS Name Microsoft Windows 10 Home
Version 10.0.19045 Build 19045
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Type x64-based PC
Processor Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz, 3501 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 4.6.5, 2/24/2012
SMBIOS Version 2.7
Embedded Controller Version 255.255
BIOS Mode Legacy
BaseBoard Manufacturer BIOSTAR Group
BaseBoard Product H77MU3
BaseBoard Version 6.0
Platform Role Desktop
Locale United States
Hardware Abstraction Layer Version = "10.0.19041.3636"
Installed Physical Memory (RAM) 24.0 GB
Total Physical Memory 24.0 GB
Available Physical Memory 9.24 GB
Total Virtual Memory 48.0 GB
Available Virtual Memory 24.5 GB
the software I installed is:
I tried installing just the scanner, multiple times, all failed. Ive tried completely uninstalling everything, reinstalling, and still the same problem.
I can print just fine, but cannot install the scanner, let alone use the MF Scanner tool, which of course does not find the scanner when I open it, because the scanner isn't "installed".
Is the PC link you provided different from the "recommended" drivers on the MF743Cdw page?
Thank you!
06-19-2024 07:33 PM - edited 06-19-2024 09:38 PM
Greetings ,
Different software, no it's not. You're installing the correct utility 1.21.0.2. This is correct for the scanner and windows 10 / 11
By chance, did you have any other Canon printers installed prior to installing this device?
Do you have a third party antivirus installed? Something other than Windows Security that comes with the OS. If so I'd uninstall it, restart and try to reinstall the application again.
Here is a link to a helpful Microsoft utility. It's provided directly by Microsoft.
Microsoft install / uninstall troubleshooter
Run this if you continue to experience installation issues.
For clarification
This is for the printer
[Windows 64bit] MF743Cdw/MF741Cdw MFDrivers (Generic Plus UFR II / Generic FAX / ScanGear)
This is for the scanner
[Windows 32bit & 64bit] MF Scan Utility Ver.1.21.0.2
06-19-2024 10:09 PM
@shadowsports wrote:
Greetings ,
For clarification
1, No, no other Canon printers previously
2. YES, i have Webroot installed; should I just pause it vs uninstalling/removing it?
3. "
>>> OK, but it includes the scanner as a driver to be installed..?
06-20-2024 12:18 AM
One of my clients just brought me a laptop he had put Webroot on. Thats when his problems started. What a mess that was. I wiped the machine and reinstalled his OS. You can do what you like, but my recommendation is dump it.
The MF Installer does not include a scanner driver. ScanGear is an application. You have to install the v1.21.0.2 driver for the scanner to actually operate on a computer. This also allows you to use the ScanGear application.
Use the names of the installers I referenced above. These are the two files you need to install. 😀
06-20-2024 12:58 AM
Ok should I just uninstall webroot and go with Windows antivirus?
Thank you again!
06-20-2024 08:18 AM - edited 06-20-2024 08:25 AM
Greetings ,
Windows Security is adequate for personal use. It's what I use the majority of the time. For my business clients, I recommend SentinelOne, Crowdstrike or Bitdefender coupled with a backup strategy. These provides defense against virus, malware and crypto. It's important to practice safe browsing habits and good internet hygiene. Webroot is not known for its detection capability or compatibility. Free items are often given away for a reason.
06-20-2024 06:34 PM
Unfortunately, my version of webroot is NOT free. I will go back of all of your advise and, uninstall webroot, and try again. Thank you!
12-13-2024 09:17 PM
I just wanted to reply to confirm that Webroot WAS the problem; that, and I found the installed scanner under Device Manager, was *disabled*.. so every time i'd try to install it, it would install another disabled version (or webroot was disabling it), to the tune of 8 or 9 scanners 😄 Uninstalling Webroot, deleting all but one of the scanners in DM, enabling the last one, did the trick.
THANK YOU!
