05-21-2023
01:52 PM
09:27 AM
06-06-2023 01:09 PM
Hello Aebtty,
To scan from a Mac running Ventura, you would need to download and install the Scanner Driver & Utilities for Mac V2.15.12 [macOS 10.13.6 - macOS 13.3.1] from our Canon USA support site. Once the driver and utility is installed, you will have the scanner software needed. The program that will install is called the MFtoolbox and it will appear in application in a folder marked Canon utilities. The software will give you the ability to perform scans and change the scanner settings.
06-07-2023 01:43 AM
Alas, the Canon printer is in my vacation home, which I just left the day you sent this, & I'm not going to be there again until July. Maybe I can try this then.
12-13-2024 07:39 PM
Where can i download image class printer drivers MF
200 series
12-13-2024 11:45 PM - edited 12-13-2024 11:49 PM
Hi. You'll also find the imageCLASS MF269dw print drivers under software downloads here
