imageCLASS MF743Cdw Error 230, Scanner driver not installed
vinod
Purchased a new MF743Cdw and tried to install the Printer software and MFscan Utility tool. Everything installed. Printer works flawlessly. But when we launch MF Scan utility tool it keeps throwing an error as "A scanner driver supporting this software is not installed. Install it and try again.". Removed and re-installed but the issue still exists. Does not know how to move forward. Any help
3 REPLIES 3
psychobroker
I have been having the same problem for months and have GIVEN up, after spending hundreds of $$ on genuine canon printer ink, I cant use the scanner!!
1. "Could not install the scanner driver. Try to install again." x 10000
followed when I run the MF utility:
2. "A scanner driver supporting this software is not installed.  Install it and try again". - SEE #1  !@#$$
HELP!
Hello!
So that the Community can help you better, we will need to know more information:
• Which version of Windows or macOS are you using?
• How do you connect to your printer (USB or WiFi)?
Any other details you'd like to give will only help the Community better understand your issue.
If you're in the United States, and this is an urgent support need, please click HERE to visit your My Canon Account to discover your personalized support options.
If you're outside the USA, please click HERE to find support options in your country.
Thanks, and have a great day!
@Stephen,
Good morning.  The user has another thread, his own which I referenced here previously and replied to.  🙂
https://community.usa.canon.com/t5/Office-Printers/ImageClass-MF743Cdw-Cannot-install-the-scanner-Wi...
