imageCLASS MF656Cdw could not create a port due to fax drivers are currently in use error
dab0054
3 REPLIES 3
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, let us know which version of Windows or macOS you are using? How are you connecting? What is the exact error message?
Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
dab0054
In windows 11, trying to delete canon mf650 series drivers, states fax drivers are currently in use.
Greetings
The "could not create port error" displays during installation not removal 🤔. If the Fax service is running, you can kill it in task manager.
Please answer Tiffany's questions when possible.  🙂
