imageCLASS MF656Cdw printing issues on White Glossy Labels
onceuponacandle
Have a small home-based business. We print our own labels. The ImageClass MF656Cdw laser printer has intermittent issue when printing on white glossy label paper. It is Avery label paper that is supposed to be laser/inkjet compatible. The printer partially prints a sheet but then will not feed, resulting in a paper jam error. Have tried multiple paper settings with no luck. Printer works fine printing labels on kraft brown paper. Thank you for any suggestions you may have.
1 REPLY 1
I've only used Avery labels for laser.  I print from Word and use a calligraphy style font for Christmas cards.  No jams or misfeeds.  Mine are clear with a glossy finish. I got them at Staples.  I think I selected plain paper 8.5x11 to print and load them into the paper drawer.  Label side down if I remember correctly 🤔
The only tricky thing is when you start halfway down a page.  You have to count down the page to make sure you start it the right spot.
