imageCLASS MF267dw Scan to email issue
bgelfuso
Hello I'm trying to assist a client with an issue with scan to email on his imageCLASS MF267dw. Whenever he tries scanning to his email it says "Canceling" on the display and then prints out a TX Results Report with "Error" next to his email address.
I have set up his email through the UI on the computer at "http://<the IP address of the machine>/sendsupport_login.html" with no luck. The SMTP Server is correct as well as his login credentials. I installed the printer drivers and updated the firmware on the scanner itself which made no difference.
It is a network printer also. Any ideas?
1 REPLY 1
Hector
Hello Bgelfuso,
We would be happy to assist with the issue. To provide some feedback or some troubleshooting steps, we would need some additional information. If you could reply to this message with the information below, we can provide some assistance.
  1. Which email service are you trying to connect the scanner to?
  2. In the error error port that prints, do you get an error code number? If so, what error do you get?
