03-03-2018 05:38 PM
I purchased a second laptop. I am able to print from either laptop, but despite loading MP Navigator EX on the new laptop, I cannot determine how to make auto scans (from the scanner) go to the new laptop. They always go to the new laptop.
03-03-2018 11:56 PM - edited 03-04-2018 12:02 AM
You should be able to perform the same steps to set up the scan to folder destination as done previously.
Knowing the model of printer you are using would also be helpful.
03-04-2018 10:23 AM
Thanks. Model is MX 432. I have no problem setting up the folder desitnation on the laptop. But it's been 4-5 years since I setup the (old) laptop as the device destination, so any tips would be helpful. Currebtly every scan goes to the old laptop and I can't find an option that let's me establish the new laptop as the scan destination.
03-04-2018 11:35 AM
I haven't looked at your manual yet, but by looking at the printer, I'm pretty sure is has a webserver, Log into its webserver using your browser. If you don't know what it's IP is... look in your routers configuration, "Connected devices" and/or view or print a network configuration page from the printer to gleen its IP.
Once in the webserver, you'll have an option to set or change the existing Scan To Folder destination. It will look something like this. You can add the new destination, delete the old one or keep both:
