can't setup wireless connection Canon pixma pro-100
isabelrb
Hello, I recently changed the wifi setting of my network, we changed the network password, and now the printer is offline and I haven been able to reset it. I tried connecting it to my mac and going through the setup again, but it doesn't work, the wifi light blinks fast and the cancel button lights up, y restarted the router. I'm trying to follow this instructions here http://gdlp01.c-wss.com/gds/1/0300008421/01/PRO-10_PRO-100_NonPC_EN.pdf but I don't know what the access point is? How can I fix this?
Thank you
21 REPLIES 21
I need an easy fix. looks to complicated, please
I had to find my cable and connect it via usb. I cannot find my original set up disc, and I just cant get it done without it. Im lost. ugh
You can download all software from here. Don't need CD.
https://www.usa.canon.com/internet/portal/us/home/support/details/professional-large-format-printers...
How can I order a new or replacement setup cd/disk for my pixma pro 100, please?
I don't know if Canon sells them, but even if you could it would be an 8 or so year old item.
The latest versions of all software are on the Canon support site.
I found 2 drivers. I tried both the xps and the regula. after they loaded they said download successful but I get nowhere. I am lost. I cannot save the thing and do anything else wqith it. VERY FRUSTRATING. ugh!
jrhoffman75
Forget about XPS, just use the regular driver.
After you download the driver you need to install it.
Turn printer off and remove USB cable.
Double click on the downloaded driver and it will install. Follow the directions that appear.
How to Download and Install
Download / Installation Procedures
1. Click the link, select [ Save ], specify "Save As", then click [ Save ] to download the file.
Memo :
If you select [ Run ] ( or [ Open ] ) instead of [ Save ], the file will be automatically installed after it is saved.
2. The downloaded file will be saved in the specified place in the self-extracting form ( .exe format ).
3. Double-click the downloaded EXE file to decompress it, then installation will start automatically.
What link1?
All I get is this>>
 p86I_win_pro_100-....exe
There is no thing to click run after thge install. I just want this to be wireless on My new ATT interent. I flat need lamens terms help. please
Any help?
jrhoffman75
Give Canon a call at 1-800-OK-CANON. They are better equipped to assist you.
Friends and Family
