I ran snmpwalk for a Canon 1022 and 1024 to get the OID for the serial numbers but with no results
I ran snmpwalk for a Canon 1022 and 1024 to get the OID for the serial numbers but with no results help
I'm losing my mind. I got my PIXMA MG5420 to print wirelessly, then something happened and I lost the connection. now I can't remember what I did last time to get it to print wirelessly. Using Window 8 as operating system, port is USB001 virtual pri...
I am trying to set up my Chromebook to this printer, i already set up the printer to my wifi but it says to press and hold the WPS button on the access point then press ok of the device. first of all my wifi router does not have a WPS button, and it ...
Hi, I just got the Pixma MG2520 and can not get it to connect to my computor. Is this printer able to connect to my computor wirelessly? thanks for your time
Hi.Product's an MX490 Pixma. it used to work well until I download this program called Not Another PDF Scanner 2. After I did, I used it and connected the laptop to the printer using a cable (was using wireless connection before). After using it, I f...
So I am unable to connect (whether via WPS or USB) my new MG3550 printer to my network. The tool comes up with "cannot detect the printer on the network" and the Netwok Info I get is as follows: ========================================Network Informa...
Hi, I am having this same problem others have reported. I am running mulitple MacBook Airs with latest Mac OSX. With the latest the Apple OS upgrade, the Canon MX410 printer keeps going offline for wireless network printer.I am using the latest drive...
How do i get it back on line?
My5620 connects to the access point with either connection method, password or pushbutton, but the printer doesnt appear in the printer list when I run the setup guide from the cd. Using Windows 7. Could there be a problem with the modemsettings? ...
Canon MX 922 with a Window 10 will not configure the printer.It continues to stay: offline
Trying 2 set up my old Mp640 with static ip, but cant enter the advanced section via IE since i dont have the password (or the manual) /thanx
MF tool box is installed on computer but when attempting to use it, says cannot communicate with scanner. I can print via the wireless network but cannot scan.
MF Tool Box 4.9 cannot connect to MF6160dw MF Tool Box 4.9 was connecting fine to MF6160dw to use the scanning functions under Windows 10.I just upgraded to the latest version of Windows 10Windows 10 Pro Version 1511 OS Build 10586.36Now MF Tool B...
I have a Canon Pixma MG3100 series printer/scanner. It is connected to my wife's PC by wire. I am able to print from my laptop which is wirelessly connected via Home Network but when I try to Scan a document Windows 10 cannot detect the printer/scan...
Hello, I have just installed a Canon MG7520 printer via a USB cable only - not through any wireless network. I do not want the printer to be able to access the internet in any way and wanted to be sure that using strictly a USB connection will accomp...
| Subject | Author | Posted |
| 09-21-2026 01:22 PM | ||
| 09-15-2026 07:21 PM | ||
| 09-13-2026 07:01 PM | ||
| 09-10-2026 02:37 PM | ||
| 08-14-2026 05:48 PM |
