PIXMA MG3022 How to find IP address
Hello - does anyone know how to find the IP Address for the Pixma MG3022 printer? Thanks!
My Pixma ip100 printer keeps dropping it's wireless connection. I restart my Win10 x64 bit system and printer, reconnect bluetooth and setup the printer. The connection stays for the rest of the day. The next day, when I turn my printer on, the co...
Good evening folks, wonder if you could help. We have a PIXMA TS5150 that has worked fine for about 15 months. Tonight it was showing offline from a MacBook. Tried to add the printer again by using the Canon setup utility but it soon became apparent...
I am new to this community. My MB 2700 printer that has been working wirelessly began having problems going offline. I would reboot my modeum but now that does not work. Please help.
Canon MG5750Scenario:Laptop1 prints fine on network. It’s used most often.Laptop 2 was working last December, but could not print on network a few days ago when tried. Uninstalled drivers and programmes, cleaned registry (Ccleaner), downloaded driver...
Hello, I have a Canon IP8700 that wont obtain an IP address from my router.Virgin Hub 3.0 Router. Tried via WPS and via USB. The Printer sees the network, connects - but then only gets a 169 address When i check on the router page - it shows connecte...
I get the following message when trying to install the driver for my Canon Color imageCLASS MF743Cdw. The complete message is WinZip Self-Extractor Error 5 running command .\DRIVERS\x64\Setup.exe I ran it normal and as an adminstrator - sam...
I have follwed all the instructions to connect the printer to my wireless network, was successful but my computer needed repair and had to connect it again. I was abel to cnnect it but for some reason after a few scans with the MF Scan Utility it dis...
I bought an pixma Pro 100 and I cannot connect to the WiFi with my iPad Pro nor phone and I don’t have an computer I don’t know why it doesn’t respond the WiFi?
After installing the latest firmware update (v03.05), printer will no longer print. When I send print jobs from my desktop, the job will reach the printer and it will be in "Waiting" or "PAUSED" status and will not print at all. I tried disconnecting...
How do I find the IP address for this new printer to continue with wireless set up? I was only able to hook up printer using a USB cord, and once I get the printer hooked up through wireless will I need to remove the USB cord hook-up?
PIXMA MG3620. Going through the installation process on a new printer, I successfully get by the 1st 3 setup steps of using a wireless connection, which includes a message that the connection was completed. Then in the final step it reaches a point...
I've been trying to setup a wireless connection between my new Cannon MX492 and my wireless router. The printer keeps asking me to press and hold the WPS button on my router for 5 seconds. My router doesnt have a WPS button. Am I reading this wrong...
I am trying to connect my printer to the Wi-Fi. I found this posthttps://community.usa.canon.com/t5/Wireless-Networking/My-printer-won-t-prompt-for-a-password/m-p/282838/highlight/true#M7138. On the printer Home screen I tap the wired symbol at the ...
| Subject | Author | Posted |
| 09-15-2026 07:21 PM | ||
| 09-13-2026 07:01 PM | ||
| 09-10-2026 02:37 PM | ||
| 08-14-2026 05:48 PM | ||
| 04-28-2026 08:20 AM |
