Wireless connection fail - PIXMA G3270
gab1138
Last night, my G3270 Pixma wireless connection failed. It's worked flawlessly for a year and a half.
I went through all of the troubleshooting steps, but nothing works. ( I also chatted with tech support today.)
The G3270 connects by WiFi to a personally owned Belkin ShareMax N300 router. The router then connects to my ISP's box. So I rule out the ISP box as part of the problem.
I tested the Belkin WiFi, that's not the problem. I connected another wireless device to it and that worked. Tech support also does not think the network card on the printer has gone bad.
The chat support today suggested that I set up a static IP for the printer.
From what I have found so far, it is my desktop computer that is controlling DHCP. It would also seem that if I turn off DHCP on my computer and set a static IP for my printer, I would also have to do the same for my computer.
Or, the brute force option is to connect by the USB port.
Thoughts and suggestions appreciated. Thank you!
Patrick
Hi gab1138,
Please follow these steps to print the network pages from your G3270:
1.  Press the Home button on your printer once.
2.  Press the down arrow 3 times to select Settings and press OK.
3.  On LAN settings, press OK.
4.  Press the down arrow 2 times to select Print details and press OK.
5.  Yes is selected.  Press OK.
6.  Please load letter sized (8.5" x 11") paper in your G3270 and press OK.
7.  Choose Yes or No to the question asked and press OK.
3 pages will print.
What is listed to the right of 3-2-12 IP Address?  There are 4 sets of numbers.
Are the first two sets of numbers 169.254?
If so, that is an APIPA address.  Please view the information provided on the page linked below:
Canon Knowledgebase - What is an APIPA?
6 REPLIES 6
Patrick
Hi gab1138,
3 pages will print.
Patrick,
THAT DID IT!
Restarting the router was the only thing they didn't suggest, nor did I think of it either.
Thanks for your help! 😀
Hi gab1138,
You're welcome!
I am having the same issue. I followed your tips but my IP address does not start with 169-254. My printer keeps disconnecting.
I have the same printer with the same issue. The numbers listed to the right of 3-2-12 IP Address aren’t as listed above but are 192.168.  Was able to use this printer for maybe a couple days then not. ANY help to resolve this would be VERY appreciated.
suzanwebb
I printed the Network Configuration Page and there are NO numbers next to 3-2-12 IP Address. What do I do now?
Friends and Family
