03-06-2025
03:40 PM
08:10 AM
James_C
Last night, my G3270 Pixma wireless connection failed. It's worked flawlessly for a year and a half.
I went through all of the troubleshooting steps, but nothing works. ( I also chatted with tech support today.)
The G3270 connects by WiFi to a personally owned Belkin ShareMax N300 router. The router then connects to my ISP's box. So I rule out the ISP box as part of the problem.
I tested the Belkin WiFi, that's not the problem. I connected another wireless device to it and that worked. Tech support also does not think the network card on the printer has gone bad.
The chat support today suggested that I set up a static IP for the printer.
From what I have found so far, it is my desktop computer that is controlling DHCP. It would also seem that if I turn off DHCP on my computer and set a static IP for my printer, I would also have to do the same for my computer.
Or, the brute force option is to connect by the USB port.
Thoughts and suggestions appreciated. Thank you!
03-11-2025 05:13 PM
Hi gab1138,
Please follow these steps to print the network pages from your G3270:
1. Press the Home button on your printer once.
2. Press the down arrow 3 times to select Settings and press OK.
3. On LAN settings, press OK.
4. Press the down arrow 2 times to select Print details and press OK.
5. Yes is selected. Press OK.
6. Please load letter sized (8.5" x 11") paper in your G3270 and press OK.
7. Choose Yes or No to the question asked and press OK.
3 pages will print.
What is listed to the right of 3-2-12 IP Address? There are 4 sets of numbers.
Are the first two sets of numbers 169.254?
If so, that is an APIPA address. Please view the information provided on the page linked below:
Canon Knowledgebase - What is an APIPA?
03-11-2025 05:13 PM
Hi gab1138,
3 pages will print.
03-11-2025 09:19 PM
Patrick,
THAT DID IT!
Restarting the router was the only thing they didn't suggest, nor did I think of it either.
Thanks for your help! 😀
03-12-2025 02:31 PM
Hi gab1138,
You're welcome!
03-28-2025 11:28 AM
I am having the same issue. I followed your tips but my IP address does not start with 169-254. My printer keeps disconnecting.
06-25-2025 10:59 PM
I have the same printer with the same issue. The numbers listed to the right of 3-2-12 IP Address aren’t as listed above but are 192.168. Was able to use this printer for maybe a couple days then not. ANY help to resolve this would be VERY appreciated.
