01-23-2022 06:10 PM
My old Pixma MP480 is scanning fine, but how do I get rid of the white space on a photo scan? On the jpeg, the photo ends up in the corner with a ton of white space (the rest of the scanning plate) around it. Can I get rid of that in settings so I don't have to manually crop hundreds of photo scans?
01-24-2022 09:27 AM
Does your scan tool setting have a display similar to this?
When I select Auto the scanned PDF is just the 4x6 print I place on the scan surface.
01-24-2022 12:30 PM
Thank you for trying to help me. The scan tool I am using is My Image Garden. It has a menu options for printing, organizing files, ans scanning, but the scanning section is not active, like it doesn't recognize that the scanner is connected to my Mac. I just reinstalled the scanner software, and same thing. Also, there are no scanning options on the scanner menu except for where to store the images.
01-24-2022 01:00 PM
It may be that the scanner function isn't supported by your version of macOS.
You could try software called VueScan from hamrick-dot-com. They have a free trial.
I have no commercial relationship with them except being a satisfied customer. Their software allows me to use my old Minolta scanner that stopped having factory support with Windows XP. I have recommended it to several folks on the forum that had obsolescence issues and they now have functioning scanners.
01-24-2022 06:38 PM
I finally figured out that I can use the scanner settings via my Mac instead of the Canon app to be used with the printer. Ultimately, your advide led to the solution, thank you.
