Unable to install CANON PIXMA TS3522
jayflora
I'm trying to install CANON PIXMA TS3522 but getting error:
To install the software, you must be logged in to an administrator account. Click (OK) to cancel the installation. If you are using the CD-ROM, remove it after clicking [OK]. Log in to an administrator account, then install the software
Already logged in as an administrator.
Below resolution will not work. Not found in Pixma TS3522 installer.
1. Unpack the driver's .exe into a folder
2. Locate msetup4.ini file and open it in Notepad
3. Search for [CHECKADMIN] section
4. Change IFNE=%ADMIN%,0 to IFNE=%ADMIN%,1
5. Save, and run Setup (M4SETUP.EXE)
Please help. Thank you!
5 REPLIES 5
Stephen
Moderator
Moderator
Hey there! I'm not a tech, but I've installed several printers in my time! Try the software HERE. Once you download it, right-click it and install it as an administrator.
If that doesn't work, let us know!
Hi Stephen,
Thanks for the response. Already tried this one but it's not working either.
normadel
Try this:  When you go to run the installation file, right-click on it and select "Run as Administrator".
It's not working either. Also tried running the exe file via CMD (admin). Same error.
A couple of suggestions for you to try.
First.  Right-click on the file, Select Properties >Security tab > Advanced button.  Who is the owner?  If the admin user you are logged in as is not, Take Ownership.  Ensure this user has Full Control. Delete any unzipped directories or folder and unzip again, then run.
The file is a self extracting .Zip
Start by deleting all copies of the file, and any folders or directories where you unpacked it and attempted to run it from.
Using Stephen's link above, download a fresh copy of the installer to your downloads folder or desktop.  Right-Click on it and select Properties.
Check the "Unblock" checkbox box and press OK.  Now unzip and attempt to run it again.
If that doesn't work. Delete the folder where it unzipped to again.
Right-Click on the self-extracting executable and this time select "Rename".
Change the extension from .exe to .zip
Now unzip and attempt to run the installer again.
Note you must have file extensions set to display to rename properly.  Otherwise you'll wind up with this.
Hope this helps.
