02-18-2022 12:10 PM
Just got Starlink internet. Changed settings in printer to Starlink. Tried printing and it takes a long time for the print job to go to the printer. Once it even timed out. Did not have that issue with my old internet provider. How do I fix this?
02-19-2022 09:17 AM - edited 02-19-2022 09:18 AM
Your internet provider does not have any impact on printing. You are printing from your computer to a local device. You do not need internet connectivity to print. If your StarLink were to be down due to weather for example, you could still print.
For us to try and help, we will need to know the following:
The model of your printer?
The OS you are using it with (version and build)?
What is the printer connected to and how?
I've been waiting for StarLink for over 2 years. I want to use it on our boat. We've used Wi-Line in the past, but the tower we are pointing to has been taken over by several TV and radio stations whose signals have degraded the ISP's Wi-Fi broadcast to dismal performance. If you answer the questions above, I'm sure we can provide some pointers.
02-19-2022 12:55 PM
Not sure what the issue was but it is working fine now. Thanks.
03-01-2022 04:40 PM
My printer is setup for wifi so I can print wirelessly. Sometimes it works and sometimes not. When it doesn't work, I get the message that the printer is off line. If I turn the printer off and then back on it works. Now I just tried to scan something wirelessly and it did not work. Kept getting error messages. I finally had to use a USB drive to scan the document to the USB drive and then connect to my laptop. Would updating the drivers help?
