Removing multiple instances of a computer from an MF8350cdn network scanner
mhwolf
I am using an MF8359cdn as a network scanner/printer with 3 computers on the network.  All print properly.  When i attempt to scan from the 8350 keypad, at the Select COmputer screen, one computer is listed 10 times.  When i select any of the ten instances for that computer, the scan functiontimes out.  When i try to configure the Network Scan Utility on that computer by selecting the 8350 as the scanner, I get the "Too many devices connected" error.  How can i remove the 10 instances of this one computer from the 8350 menu?
1 REPLY 1
Deborah
Enthusiast
Hi mhwolf,
The duplicate listings of the single computer is a symptom of an issue with DHCP routing on your network.  A reboot of your whole network assists in resolving the issue.
