03-07-2019 07:43 PM
I upgraded the router and the printer does not seem to recognize the new WiFi network. How can I reconfigure it?
03-07-2019 11:23 PM
From your printers support page:
03-11-2019 02:02 PM
Hi plabaste,
Just wanted to check in and see if your were able to get the printer reconnected. If you were able to, please click the Accept as Solution button in shawdowsports reply post so that others may find the answer as well.
We look forward to hearing back from you.
03-11-2019 10:08 PM
Nope
03-13-2019 02:59 PM
Hi plabaste,
What version of Windows or Macintosh is installed on your computer? Also do you still have the usb cord that came with the printer?
03-13-2019 03:43 PM
Windows 10.
Unfortunately not.
03-15-2019 03:14 PM
Hi plabaste,
If your router has a WPS button ( would say wps, has an icon of curved arrows or an icon of a lock) then please click HERE for steps to connect the printer via the WPS method.
If your router does not have a WPS button, you would need to get a printer usb cord(A to B usb) cord and use that to during the install to connect the printer to your network.
03-17-2019 07:11 PM
Hi ArthurJ,
Thank you for your advice.
The router does have a WPS button.I followed the step-by-step procedure as indicated and aftre a couple of unsuccessful attemps I saw the message procedure completed successfully on the printer. The bad bnews is that when I try to print I still get the Error message: Printer not responding.
03-20-2019 02:45 PM
Hi plabaste,
I would get the network setting on the printer. Please click HERE for steps on checking the Wireless LAN setting list.
Once you are able to see the settings, please let me know what the connection and signal strength is. I would also make sure the SSID matches the network your computer is connected to.
03-21-2019 07:35 PM
Hi ArthurJ - I checked the Wireless LAN Setting List as recommended. It shows that the connection is Active and displays as SSID the computer's network name. However it still impossible to print. It doesn't show any information on signal strength.
