11-13-2022 08:05 PM
Pro Print & Layout has suddenly failed to load - both as a stand-alone and a photoshop plugin from my Desktop HDD. (Windows 10 Pro 64bit). I am able to print a test sheet successfully (over WiFi) from the settings/Printer & Scanners/Canon Pro-2100. Troubleshooting has found no problems. I have reinstalled Windows 10 with the latest build in an unsuccessful attempt to remedy the problem. The SSHDD & RAM has plenty of free space
The software loads perfectly and I am able to print on/from my laptop.
I have reinstalled printer drivers and all software. The printer Imagepro Pro 2100 is functioning perfectly connected over the Wifi, everything seems to be configured correctly. Only Professional Print & Layout refuses to open.....grrrrrrrr.
Can anyone help, please?
11-26-2022 12:32 PM
I found your post and have the same problem....except my Professional Print and Layout has never opened up. Windows 10 Home with 64 bit.
As I mentioned...my Professional Print and Layout downloaded, but will not open up. All other software works okay.
You would think a Canon Tech could read these once in awhile and give some input on what to do. Double grrrrrrrr.
12-03-2022 12:22 AM
Thanks for your feedback.
I contacted Canon NZ (I live in New Zealand!) and the recommendation was to have a technician visit. That was a disappointing response. I assume we are not the only Canon customers with the problem and I would have appreciated an explanation.
I have run a comprehensive hardware health check, software, drivers and OS is up to date.
I have completely removed the software and cleaned the registry using Revo Uninstaller and then downloaded and reinstalled it - still not opening!
I have disabled DEP - still not opening!
Program Compatibility Troubleshooter run and reports - 'Incompatible Program' and 'Not Fixed'
Interestingly, I have copied the software app from my laptop onto a USB memory (Flash Drive) from which the program will then open on my Desktop PC as a standalone from the flash drive.
The next step I will attempt is check for competing Apps.
Just a quick call from Canon would be appreciated, rather than a technician visit and charging just to enter my premises. Yes Grrrrrrrr
12-03-2022 06:20 AM
I don't work for Canon and I am not a fanboy defender, but 1. many people sucessfully use PP&L, and 2. you demonstrated that the software will work on a different computer of yours, so you are apparently dealing with some unique problem with your particular configuration.
1. it may not be a Canon problem and 2. things like that can be very hard to diagnose.
