Pro-1000 Printing issues from Canon Professional Print & Layout
srboynton
I print on a Canon Pro-1000 connected via USB to a windows 11 PC.  I had been printing using either PS or LR (both most recent versions) but loaded Professional Print & Layout for more accurate printing with fewer 'reprints'.  The plug-ins for Professional Print & Layout are loaded and fully functional in both LR & PS.  Photos correctly load from LR & PS into Professional Print & Layout and all is good until I press print.
I get an error in the print Q stating to check the UI (not sure what this is) or the printer panel - no further info.  I note that the printer que shows an IP address for the Pro-1000 - should it if connected by USB cable and the LAN setting set to USB?
I can still print directly from PS and/or LR.  can anyone help??
srboynton
embarrassed to say - the issue was in Professional Print & Layout set-up - it selected the printer and forced an IP address even though the printer was configured in the printer and PC as USB (both wireless and network configurations were not made).
I forced Professional Print & Layout to recognize a USB printer and everything works.
2 REPLIES 2
srboynton
EC3
The Pro 1000 printer is connected to network using wired connection. When I try to select a printer in the PPL software, I get an option to pick PRO 1000 Series followed by an IP address. I am trying to add the XPS driver I just installed but it is not an option in the add printer dialog box.
As i understand it, the printer has two separate drivers. Is there a way to select which driver to use with the PPL software instead of PRO 1000 series?
thanks
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
