Printing a network information sheet from a MG3520
Terrbear
Hello,
I have been trying to set up this printer that I had just bought as I do not have a usb cable.
I have tried everything on the set-up disc to no avail.
I tried printing the network information sheet by pressing down on the stop button till the orange light blinks 6 times, and all I get is a colorful alphabet with mostly zeros.
   I need the ip address thanks!!
How do I get it to print on a MG3520 Pixma???
5 REPLIES 5
corinaivonne94
Did you ever find out how to fix this because I'm having the same problem
Hello corinaivonne94,
To print the LAN details page, follow the steps listed below:
1. Make sure that the machine is turned on.
2. Load a sheet of A4 or Letter-sized plain paper.
3. Press and hold the Stop button until the Alarm lamp flashes 15 times.
4. Release the Stop button.
The machine will start printing the network setting information.
will this also work on a mg2522
Hi bersi,
The PIXMA MG2522 is not a wireless printer. You can only connect the printer with a USB cable. If you're running into any trouble, check out our installation help videos by clicking HERE.
Hope this helps!
ldeplisa
Canon LIVE! Canon LIVE!
