10-03-2022
10:14 AM
09:31 AM
I have imageCLASS LBP6230dw - Wireless, Compact, Duplex Laser Printer, purchased March 2019. I upgraded my iMac to Big Sur V.11.7. Now the printer is still printing images, but won't print text. I went to download the driver to the Big Sur version, however my iMac is saying the downloaded driver is incompatable and is 32-bit instead of the required 64-bit.
Is this printer model out of support? I thought about loading a prior version of the driver, but this risks completely disabling the printer. Any help appreciated!
10-05-2022 04:21 PM
Hello JoeZabel,
You can download the UFRII LT Printer Driver Ver.1.5.9 from our Canon support site using the link HERE. The driver is compatible with Macs running 10.11.6-12.5.1. The driver install should work in a 64 bit environment. If you are getting any incompatibility messages during the install, I would suggest contacting support at 1-800-652-2666. They can assist with the install and see what issues the Mac is having with the driver install.
10-05-2022 04:21 PM
Hello JoeZabel,
10-11-2022 08:14 AM
Thanks, that worked!
