09-27-2017 12:56 PM
I have been using the Canon PRINT app so that I can scan documents. Both printing and scanning only worked once and then disconnected and won't reconnect. I have tried disabling the IPv6 setting on the printer, but it still disconnects from the app.
03-29-2019 03:39 PM
Hi chance,
What was listed by IP Address? Was that section blank or did it start with a 192 or 10?
03-26-2019 07:07 AM
yes I have done all and the findings are:-
signal is inactive
SSID matches the same as computer
Signal strength is 52% (computer and printer are in the same room and my internet is always full bars connected)
03-29-2019 03:43 PM
Hi ejakachira,
The low signal might be a temporary issue. I recommend restarting your router by unplugging the power cord to the router for 30 seconds and then plug the power cord back in. Once your network comes back up, please turn the printer off and back on then print the network settings again to see if the signal strength has come back up.
04-01-2019 05:31 AM
04-08-2019 01:16 PM
Hi ejakachira,
You can trying disabling the IPv6 wireless setting on the printer. Please click HERE for the steps.
02-05-2018 08:01 PM
02-05-2018 08:07 PM
Hi afm914!
Thanks for joining and posting in the Canon Forums!
The Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback.
If you are in the United States and this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team.
If you live outside the United States, please click here and select your country or region for your support needs.
We hope this helps!
08-17-2019 05:36 PM
08-20-2019 02:18 PM
Hi imlaurietoo,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
