05-23-2022 02:18 PM
I cannot get Print studio Pro to show up in Photoshop 2022. I have tried installing it multiple times. The files appear correctly in the PlugIns folder, but Photoshop does not recognize them. Beyond that my Pixma Pro-100 will not print directly from Photoshop. The driver continually reports that no paper is installed. Any idea for a workaround?
Thanks
05-23-2022 03:49 PM
I did find this confirming the problem.
05-23-2022 02:22 PM
I can't verify this since I do not have that particular configuration, but I have seen reported that you need to run Ps in Rosetta mode for the plugin to work.
05-23-2022 03:27 PM
Thanks. I’m afraid that would mean going back several versions. My understanding is that Ps after 22.3xxx is native Apple processor dependent.
05-23-2022 03:49 PM
05-23-2022 04:03 PM
Thanks again. I’ll look into running two versions of Photoshop.
05-23-2022 04:09 PM
As far as printing, maybe reinstalling the printer driver will resolve that.
Unless you have developed a process that works for you, I haven’t found PSP to be a critical application or me.
05-23-2022 05:09 PM
I will try the printer driver.
I have been using PSP for several years and have my process down pretty well. It also works well with the software from my Eizo monitor. Hate to give it up unless there is no choice.
