09-13-2022
08:15 PM
09:08 AM
Printer detection fails from Canon's "TS3300 series Driver setup" running on a Windows 10 PC: I get "Could not find any printers" from the setup software and similar when I give it the printer's local IP address. This PC is connected to my (ethernet and wifi) router via ethernet cable. Our other, wifi-using, computers can see the printer (and print) fine. The printer is a wifi-connected Pixma TS-3320.
How do I get my ethernet-connected PC to print? Thanks.
09-04-2023 10:31 PM
FYI that this year, a fresh start/download from https://ij.start.canon worked like a charm. Not sure why, as everything else is the same, I believe.
09-04-2023 10:31 PM
