PIXMA TR7020 software which can scan both sides using ADF
compata
Does Canon have software which can use the automatic document feeder to scan both sides of a document comprising several pages? If not, can anyone here recommend a proper solution to this need?
2 REPLIES 2
The ADF on the TR7020 supports simplex scanning which is one side per pass.  It's possible to scan both sides of a page but you have to manually flip the page on the platen or ADF.
You didn't State the version and build of the operating system you're using the printer with?
https://www.usa.canon.com/support/p/pixma-tr7020-black
For Windows, the Print Driver and Scan Utility Installer Ver.1.04 (Windows) can be used scan multiple pages into one file.
For Mac, the IJ Scan Utility Lite Ver.4.2.0 (Mac) should allow the same functionality.
I'm using Linux but I have Windows available. I didn't specify because either would solve my problem.
I'm fairly certain that the TR7000 ADF can flip pages. So why no software to use that feature?
