PIXMA TR8520 no longer connects to Wi-Fi
saras0821
My PIXMA TR8520 printer will no longer connect to my WIFI & Network. Is it possible to obtain a new network card to replace the internal one?
I've gone through all the troubleshooting options with no luck. The printer is about 6-years old and works perfectly fine otherwise. I can't find any specs about the internal network card on it so don't know if it's possible to replace it.
Thanks for any help.
Sara
2 ACCEPTED SOLUTIONS
The TR8520 supports a 2.4 GHz Wi-Fi  broadcast that uses WPA2 encryption.  Please ensure your network meets these requirements
Tips.  If you're dual or tri-band router uses the same SSID name for all broadcasts, try giving each a unique name.  You can also temporarily disable the other broadcast(s) while making a connection, then re-enable when successful.
To my knowledge, the NIC on your printer is not user replaceable.  You can try calling the Canon  parts department, but I don't believe it's possible.
1-866-481-2569, weekdays from 9 AM - 7 PM, ET.
Thanks for the response Rick. Yes my router meets all the requirements and encryption. Printer has connected for several years with no issues. I was afraid the answer might be that the NIC isn’t  replaceable but was hoping someone might a better idea than buying a new printer. This one works fine when I connect it directly to my laptop w/USB!
 Of course, why would Canon give us an option to replace a NIC when we could just buy s new printer instead. I appreciate your response, Rick.
Thaln you.
sara
5 REPLIES 5
Thaln you.
sara
kridder77
I was just going to ask this question, it worked when I lived in a house a few months ago and hasn’t worked since I moved into an apartment.  My WiFi works fine on all of my other devices but I cannot print from my iPhone now.
DerrickL
You have your own 2.4ghz WIFI in your apartment? You have admin access to the router?
I have the router in my apartment so I’ll have to call the internet provider to ask about the 2.4 ghz WiFi.
