01-08-2026
09:33 PM
09:54 PM
StevenMOD
PIXMA TR7422 how to connect to new wifi name
01-08-2026 10:23 PM
A new SSID name? Connecting Canon TR4722 to Wi-Fi
Method 1: Easy Wireless Connect Setup
Turn on your Canon TR4722 printer.
Press the Settings button on the printer's control panel.
Select Wi-Fi setup and press OK.
Choose Easy WL Connect and press OK.
Follow the instructions displayed on the printer to connect via the Canon Print App on your smartphone.
Method 2: Manual Connection Setup
Power on the printer and press the Settings button.
Choose Manual Connect and press OK.
The printer will search for available networks. Use the control panel to select your Wi-Fi network.
Enter your Wi-Fi password using the printer's keypad and press OK to connect.
Method 3: Wi-Fi Direct Setup
Turn on the printer and press the Settings button.
Select Wireless Direct and press OK.
Enable Wi-Fi Direct by selecting Yes and pressing OK.
Connect your device to the printer's Wi-Fi Direct network using the provided credentials.
Final Steps
After connecting, ensure your computer or device is on the same network as the printer.
Print a test page to confirm the connection is successful.
These methods will help you set up your Canon TR4722 printer to your Wi-Fi network effectively.
