PIXMA TR4520 Wi-Fi setup generates error code 3441
Kgeorge
Good morning.
I bought this printer year ago and finally trying to set it up. I am trying to connect my pixma 4520 but it wont configure with my wifi system.
Whenever I try connect it to my wifi is gives error code 3441. Is there anyone who is able to help me with this?
3 REPLIES 3
Kgeorge
Pixma TR4520 series
DerrickL
Understanding Error Code 3441
Error code 3441 typically indicates a failure in the Easy Wireless Connect feature of the Canon TR4520 printer. This error can occur during the Wi-Fi setup process.
Troubleshooting Steps
  1. Retry Easy Wireless Connect
    • Press the printer's OK button to attempt the connection again.
  2. Alternative Setup Method
    • If the error persists, consider using a different method to set up your Wi-Fi connection. This may involve using the printer's control panel or connecting via USB.
Additional Information
  • Error codes like 3441 are designed to help users identify issues with their printers. They appear on both the printer's LCD screen and the connected computer.
  • Manually Connect printer to WIFI.  Preparing for Connection, 2 options.
    1. Turn on the Printer: Ensure your Canon PIXMA TR4520 is powered on.
    2. Access Wi-Fi Settings: On the printer, press the "Home" button, then navigate to "Settings" and select "Wireless LAN setup."
    3. Select Wi-Fi Setup Method: Choose  "Manual Setup".
    Connecting to Wi-Fi
    Using the Printer's Control Panel
    • Select Network: Choose your Wi-Fi network from the list displayed on the printer.
    • Enter Password: Input your Wi-Fi password using the printer's keypad.
    Using WPS (if available)
    1. Press WPS Button: On your router, press the WPS button.
    2. Select WPS on Printer: On the printer, select "WPS" from the wireless setup options.
    Finalizing the Connection
    1. Confirmation: Wait for the printer to confirm the connection. A message will appear on the screen once connected.
    2. Print Test Page: Optionally, print a test page to ensure the connection is successful.
    Troubleshooting
    • Check Wi-Fi Signal: Ensure your printer is within range of the Wi-Fi router.
    • Re-enter Password: If the connection fails, double-check the Wi-Fi password for accuracy.
    • Restart Devices: Restart both the printer and the router if issues persist
Greetings ,
In addition to the suggestions provided by my colleague, please tell us more about your wireless network.
The printer requires a dedicated 2.4 GHz broadcast that supports WPA2 encryption.
Please insure your network meets these requirements. If not, the printer will not connect.
Friends and Family
