PIXMA MG5700 Windows 11 only scans from Windows app, not Quick Menu
KeithDD
I previously used my Pixma 5700 under Windows 7. I'm now using a new PC with Windows 11. Printer connected wirelessly for both OS. Printing is fine, and the Windows Scan app scans OK, but I need to scan multi-page documents and save to PDF. I downloaded the Canon Quick Menu but it doesn't include scanning icons, and the Scan row in the Main Menu is blank.
Here is some Windows info in case that may be relevant.
  • Device Manager>Imaging Devices shows "Canon MG5700 series" and "MG5700 series_3C6E76000000" (serial number suffix) (printer and scanner?). Both sets of properties say they are working properly and both drivers are said to be up to date.
  • Control Panel>Devices and printers>Printers and scanners shows "Canon MG5700 series Printer WS". Opening that and clicking Printer settings>Printer properties shows that same printer name. Scanner settings>Scanner properties shows "MG5700 series_3C6E76000000". Open scanner just starts the Windows Scan app.
 Any suggestions welcomed. Thank you in advance.
ArthurJ
When WS is attached to the printer name that normally means that printer is using a generic Windows version of the driver. If you upgraded your operating your system and selected add printer, that is most likely what caused the generic driver to install.
To resolve the issue, please delete the printer and restart your computer. After the restart, click HERE and download/install the MG5700 series MP Drivers Ver. 1.01 file. This will install the printer and scanner driver. It will also install IJ Scan Utility which you can use to scan as well.
2 REPLIES 2
ArthurJ
Thanks ArthurJ, that worked a treat! However I deleted Quick Menu before I followed your directions in case its presence caused problems, and it hasn't been reinstalled. Can I just download it as before and reinstall it, expecting it to work this time? (I'll 'Accept as solution' once I know this. Don't want to do it now in case it closes the thread.)
Friends and Family
