08-30-2023
10:32 AM
10:35 AM
Got a new printer went to hook it up and this is the screen it gives me then kicks me out of anybody got any ideas
08-30-2023 10:35 AM - edited 08-30-2023 10:37 AM
Thanks for joining the conversation, Mhouseman212!
So that the Community can help you better, we need to know exactly which operating system is running on your mobile device (i.e. Android or iOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
08-30-2023 10:53 AM
What are you connecting to?
What is the brand a model of your router?
The printer supports 2.4Ghz and WPA2 encryption. If you are using and dual or tri-band router that uses the same SSID name for all bands or is set to WPA3 only, the printer might have difficulty connecting.
08-30-2023 10:54 AM
T-Mobile Wi-Fi.
08-30-2023 11:30 AM - edited 08-30-2023 11:31 AM
T-Mo makes several routers. Many of its newer models come preconfigured for 5G only. You may need to confirm or enable a 2.4Ghz broadcast. I cannot be more specific as you have not provided a model number.
08-30-2023 11:32 AM
It’s got the 2.4ghz and I just changed it to wpa2 instead of wpa3 I’m going to try it again with that change I don’t know if it will work
