12-12-2020 06:49 PM
Good Day,
Once logged into my system I try to print something and I get a "printer offline" message. I have to run the printer troubleshooter and that resolves the problem. However the troubleshooter says it found nothing wrong so I have no idea what it's correcting. Any assistance would be greatly appreciated. Thank you.
12-13-2020 09:44 AM
This one is easy.
Your G7020 is going to sleep after some period of inactivity.
What happens:
The router doesn't hear from the printer and assumes its no longer connected to the network. It reclaims the IP address it assigned to the printer the last time it connected. This is the IP your computer probably thinks the printer has.
Now the printer is needed. When it wakes up, or is turned on again it connects to the router.. the router views this as a new device or connection request and gives the printer another IP, however, it might not be the same one it had before.
The result is "Printer Offline". Running the diagnostics refreshes the connection and now the printer can be used again, until the next time. The same will be true if the printer is turned off for a brief period of time (or days), etc.before being used again.
To resolve, assign the printer a static IP address or reserve an IP on your router for it. This is an easy process and only needs to be done once.
Moving forward your router will give the printer the same IP address regardless of when it was last used, (went to sleep, turned off then on). Your other devices will always know how to contact the printer because its IP will not change.
12-12-2020 08:49 PM
Please tell us how the printer is connect and to what?
Also the OS you are using the printer with?
12-12-2020 10:51 PM
My apologies for leaving that info out. I am connected wirelessly to an ASUS router and I am using Windows 10. Thank you.
12-13-2020 09:44 AM
This one is easy.
What happens:
12-13-2020 12:52 PM
Thank you shadowsports. I'll give it a try. I appreciate your time.
12-13-2020 08:15 PM
11-22-2021 02:26 PM
Connected to a iMac 21" running OS 12.0.1 Monterey. wifi setup that had been working fine until I did to OS 12.0.1 update.
I have tried to to troubleshoot myself but it still gives "offline" message.I then tried to connect via earthnet still "offline"
06-07-2022 06:10 PM
THAT IS FINE BUT I DO NOT KNOW HO TO DO THAT I AM OLD AND DID NOT STARTNUSING COMPUTERS TILL I WAS 50 YEARS OLD
07-06-2022 06:46 PM
Hello Shadowports, how do I assign the printer a static IP address or reserve an IP on my router for the printer. Thank you.
Steve
07-06-2022 09:03 PM
The routers User Guide is a good place to start if you are unfamiliar with configuring the device.
If you can share the brand and model, maybe I can point you to it.
