08-26-2013 09:38 PM
I just purchased a new MG4120 for wireless printing. I tried to install on my Windows 8 desktop, first using the CD that came with the unit. I added it to my network using the WPS feature, and it was found and recognized fine. After installing the drivers and other software, the unit would scan wirelessly with no problems, but would not print. In the Windows 8 control panel, the printer is shown, but it says "driver unavailable."
I unistalled, and downloaded the current drivers for Windows 8 64-bit from the Canon website, and got the same result. No matter what combination of uninstall/reinstall methods I try, I always end up with a scanner that works but a printer that doesn't.
On my wife's Surface RT, I added the printer through the Add Device feature, the driver and app downloaded and she can now print wirelessly directly from her Surface. Another check that the wireless network is not the problem.
Any ideas on why the print driver is either not installing, is installing and not working, or is not compatible with my Windows 8 desktop?
Bill
09-14-2013 03:07 PM
Hi wrgilman,
When you attempt the installation using the drivers from our website on your Windows 8 desktop, do you run into any errors. If so, what is the exact error that appears?
For immediate assistance with this issue, please feel free to Contact Us!
09-15-2013 06:24 PM
Hi MarkII,
No errors whatsoever. The installation proceeds normally, and it even says that everything has installed correctly at the end. However, the driver is "unavailable" when you look at the properties of the printer.
I tried using the Metro UI of the Windows 8 PC, in order to install the printer the same way as it was installed on my wife's Surface RT. That installation begins to work, but it stops and displays "driver is unavailable."
I did some online searching, and this same problem has been encountered by others. No one seems to have found a way to fix it, though! Others, however, have had no problems on a 64-bit Windows 8 desktop. Very strange, something is not allowing the drivers to install - could it be interference with another printer (I have a Kodak AIO 5300 connected via USB) or something else?
Bill
