MG3620 IP Address is not on my network How to change it to the correct network.
Tim2035
My PC is on network 192.168.1.0 and the MG3620 is on 192.168.114.1
I can use the printer local over a USB port but not from any other device.
1 REPLY 1
Greetings ,
I recommend you choose one interface and stick with that.  If you're only going to use the printer with one system, USB is fine. If you intend to use it with other network devices, use wireless.  This will allow any device connecting to that Network to print.
To reset the network information, SSID, password and IP if one was assigned, re-run the product setup.  You can download this from the printers support portal.
https://www.csai.canon.com/support/p/pixma-mg3620
