MF3200 series driver for Windows 11
fungto43
I have a Canon MF3200 series and I want to use it with Windows 11 (Dell with Intel i7-13) now, could you please tell me how can I get the driver?
Thanks.
5 REPLIES 5
First (important) the MF3200 is a series which includes different models.
If your model is the MF3240, this is the support portal for that model
MF3240
Note, the drivers are not universal, so you cannot use drivers intended for a different model on another device.  There are no windows 11 drivers available for the MF3240, only windows 10.  These drivers will likely work with windows 11 if the 3240 is the model of your printer.
If you own a different model or one that is intended for sale in another region or country, you will need to visit Canon Global Support to find drivers (if available) for your device.
Mike
Moderator
Moderator
Welcome to the Canon Community, fungto43!
There are limited resources available for this printer, first released in 2006. Its support life ended in 2018 and no further updates are available. You can try the last driver update which was in 2017 compatible with Windows 10 and is available here: https://canon.us/41mL2ZG No guarantees. We hope it works for you. If any of our other Community members have any ideas, they're free to chime in.
Another option available to you is to speak with a Canon Upgrade Program specialist to look into replacement options at a discount. You can reach them at" 1-866-443-8002.
Hope this helps!
Thanks Mike!  Helpful.
normadel
If Canon does not list a Windows 11 driver, try the Windows 10 driver. 10 drivers commonly work with11.
My old PC with window 10 worked well, but my new PC is Window 11, how and where to download the Driver for MF3240? Thank you.
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
