08-03-2015 04:18 PM
I have a MF4570dn, and recently upgraded from Windows 8.1 to Windows 10.
I can no longer scan using the MF Toolbox utility. I had MF Toolbox 4.9 installed before the upgrade, and it worked just fine. After the upgrade, I get "Cannot communicate with the scanner" error dialog:
I thought I would try to reinstall the MF Toolbox utility, but there are two problems.
1) The downloads page shows no downloads for Windows 10 for this printer. This should be updated.
2) I downloaded the one for Windows 8.1, and tried to reinstall, but it just hangs at the "Processing Installation" screen:
I've also tried to uninstall the existing MF Toolbox first, and it also hangs at this same dialog.
I've also tried various other things without success:
- Connecting via USB instead of Network. It detects the scanner, and MF Toolbox can switch to that device, but it still gives a communications error.
- Trying the built-in Windows Scan app instead of MF Toolbox. It uses the WIA driver. It barely starts to scan, then immediately cancels.
Please Canon - forward this to your engineers and provide a fix asap. I cannot use my scanner on Windows 10.
(I can use the printer functionality just fine.)
10-05-2015 04:45 PM
Thanks. My model's links are different, but the new software appears to work.
Also, to get the old toolbox uninstalled, I had to reboot into safe mode. Otherwise the uninstaller just hung. Then booted back into regular mode, removed all traces of the existing printer, then reinstalled the new software and it works great.
07-21-2016 04:43 PM
I have a MF4550d, and recently upgraded from Windows 8.1 to Windows 10.
Please can you provide a fix.
07-21-2016 04:50 PM
I can no longer scan using the MF Toolbox utility. I had MF Toolbox 4.9 installed before the upgrade, and it worked just fine. After the upgrade, I get "Cannot communicate with the scanner" error dialog.
07-22-2016 09:42 AM
This is what worked for our office full of computers when we also got the "cannot communicate" error.
Click the search/cortana button in the taskbar, search for "services" (also found in the administrative tools in the control panel) right click on the "Windows Image Aquisition" and click properties, click on the log on tab, and change it to local system account and check the box to allow it to interact with desktop service.
07-23-2016 02:03 PM
07-23-2016 02:58 PM
This worked for me too!! Finally!!
Let's hope it doesn't break after my next Windows update......
07-28-2016 11:40 PM
previously, i had installed the latest SW and driver, changed the WIA service (steps below), and it fixed the scan issue but i couldn't initiate the scan via the start button on the imageclass (4370dn).
i haven't done 'extensive' testing but the NetworkUSBScanPatchEN.exe patch from 7/7/2016 appears to have fixed the scan issue on imageclass (4370dn) and i can initiate the scan via start button on the imageclass as well.
in particular, i recall that if you scan, disconnect computer from imageclass, power off imageclass, power on imageclass, reconnect computer to imageclass, then scan again it wouldn't work. now it does.
i listed steps that i recommend for updating SW and drivers as well. i'll respond back if i run into issues. but i have a feeling canon finally (a year later) resolved this issue.
steps for changing WIA service (in case the NetworkUSBScanPatchEN.exe patch doesn't fix your scan issue):
steps i recommend to update SW and drivers:
reboot
uninstall mf###-###
reboot
uninstall canon mf toolbox ####.mf##
reboot
install mf####-###
reboot
reboot
09-24-2016 01:02 AM
I have a MF4412, and recently upgraded from Windows 7 to Windows 10.
I thought I would try to reinstall the MF Toolbox utility,.
I downloaded the one for Windows 7, and tried to reinstall, but it just hangs at the "Processing Installation" screen:
10-02-2016 04:19 PM
I have run into this issue with my Canon MF4100...on three different OS's as updated by Microsoft. To fix this for me (latest failure) on Windows 10 was to move my Canon folder in front of a different scanners folder in the `Path` environment variable.
For all others who don't know what I am talking about...the *main* fix is to add your scanner/multi-function printer info into a certain directory in windows, then set that directory as one of the first folders in the path. See this answer
Canon Toolbox 4.9 not working with Windows 7(x64) Professional
The advice works on Win 7, Win 8 and Windows 10.
@Canon Support: Update your install program to do a `fix` scenario to add the drivers on the path. Not rocket science; just good customer service.
10-03-2016 09:02 AM
Thank you, OmegaMan! This worked for me. The MS article you linked gave simple, explicit instructions for adding my scanner's folder to the PATH variable. I tried it and MFToolbox now works for the first time since I upgraded to Windows 10 over six months ago. I can scan with MFT and make PDFs as I did in Win7. Would that Canon Support would have had figured this out.
10-20-2016 02:16 PM
Thanks a lot OmegaMan. This fix worked for me, too. Now I can scan with my Canon MF4150 once again, after my update to Windows 10. I was almost ready to give up and buy a new printer/scanner.
