01-15-2014 11:21 AM
I am trying to install my new pixma mx452 to my wireless network and it wont let me enter my password
01-15-2014 04:13 PM
This might help
Press the SETUP button on your printer's control panel.
Using the arrows, select DEVICE SETTINGS, press OK.
Select LAN SETTINGS and press OK.
Select Wireless LAN Setup and press OK.
If a message appears to press the WPS button, press STOP to cancel.
Select STANDARD SETUP from the next screen that appears and press OK.
Highlight your access point or router and press OK.
Press OK again to confirm the access point name.
Enter your passphrase using the keypad to the right.
At the screen where you enter your passphrase, in the top right corner of the LCD screen you should see a :1 . This indicates that you are in numeric entry mode. If you press the asterisk key (*) it will switch to :A or uppercase letter mode, pressing asterisk again with switch to lowercase letter mode. To enter a letter in either letter mode, you will press the associated number key to cycle through the available letters. For example: To enter a letter "c", you will press the "2" key three times.
Press OK when done.
The LCD screen will say "Connected" if the password is correct.
01-15-2014 04:13 PM
This might help
Press OK when done.
01-16-2014 08:25 AM
Thank you so much for taking the time to help me with this problem. I just assumed that the keypad was in numeric mode to start. My password is all numbers so it seemed to be working until I tried to use the zero and then would just beep, I did finally figure it out and am happily printing away. Your answer was greatly appreciated!!
07-11-2014 02:38 PM
I'm having the same problem - we switched internet providers and I need to enter the new network password; the keyboard won't let me get to the numbers.
05-31-2015 12:56 PM
06-09-2017 01:09 PM
Thank you X 10!!! Canon should have these off-the-wall instructions posted EVERYWHERE!!!! My old Canon was WAY easier you just kept hitting the "2" to get the two ... it went thru all three letter abc in lowercase then upper case ABC then the number 2 .... #whydoescanonhateme???
06-09-2017 01:11 PM
freaking unbelievable how many times I had to re-set my router .... every TIME UGH.... it's downstairs if you don't mind Canon thanks for making me run around like a freak this a.m. #canonhates
05-19-2020 01:49 AM
This does not work because I do not get a prompt to enter a password
05-27-2020 02:49 PM
Hi 296790,
Who is the manufacturer of your router and what is the model number of the router?
