Fix For MF Scan Utility Failures Windows 11 24H2
Dale_1973
I have been frustrated by this issue also. I bought a new desktop machine and it immediately updated and installed Win11 24H2 on it. I then installed my Canon software for my printer MF750C and the MF Scan Utility would fail with the message mentioned many times in this thread.
I have installed all the latest updates and including the one Microsoft released 12/10/2024, KB5048667, but none of that made the scanner software work.
Now today I reinstalled just the drivers for the MF750C under the Imaging devices in Device Manager, and it started working, and has kept working as I think I have tested after rebooting at least 10 times today.
So bring up Device Manager, (right click on the Start Menu), expand Imaging devices, then right click your device, mine says Canon MF750C Series, (2 times). Now this part is important as I checked it twice and if you don't Disable the device first it doesn't seem to work right. So right click on the device and click Disable Device. My MF750C is listed twice here in Imaging devices, so be sure to Disable Device for both of them. Then right click on it again and select Browse my computer for drivers, then select Let me pick from a list of available drivers on my computer. Your printer/scanner should be in the list, make sure it is selected, then click Next.
Mine then came back and said Windows has successfully updated your drivers. Make sure you do this for BOTH of the devices listed there, at least if it lists two of them. Windows does say it updated the device driver. I'm not sure what it did for sure but it did something.
It doesn't say you have to, but I then rebooted my machine before I tried the software, but then the MF Scan Utility works! It has kept working for 2 days now, and after many reboots!
I don't know if this will work for everyone but so far it has worked for me. I have no ideas what made it work today. Microsoft and Canon, (and apparently HP and Brother), need to talk and get this resolved for people!
Merry Christmas!
77 REPLIES 77
rhondalea
I was up until 6 am trying to solve this problem.
Nothing worked until I found a link to this thread.
I'm exhausted, but the scanner scans now. From the bottom of my heart, thank you.
I was tired of the Scan Utility not working as I need to quickly create PDF files from the scanner.  Using the MS Scan and Fax utility is very cumbersome as you are creating a separate file for each page of the document.  So, I just now rolled back from 24H2 to 23H2 and the Scan Utility started working again, exactly as before.  You only have a 10 day period to do this and I was on the 8th day, so I gave it a shot.  I will not be upgrading to 24H2 until this particular mess is solved by MS.  I read that the driver that is the culprit is affecting other scanner due to a eSCL bug.  I am getting more and more tired of MS products, including Windows.  They are constantly throwing products and features at me that I neither want nor need.  I want a lot more simplicity and reliability.  If I wanted a cell phone for doing my more complex tasks, I would use it.  I do not want that.  I really do not think this is Canon's fault.  But this eSCL bug has been going on for some months with no solution.  Canon should be alerting its customers who have registered affected products.
rustedpyre
Omg, this worked.
I've been slamming my head into a wall, even to the lengths of doing a 100% clean reinstall of Windows to fix this issue (and all my apps and files and ughhhhhhh so many hours) for MONTHS.
This fixed it.
I gave it a try without a reboot and it didnt work and I almost gave up. But ran through it again and gave a reboot and it worked. I am in awe that such a simple fix did it.
Wtf Canon. Get it together.
Dale_1973
I saw this article today, seems like the issue is not completely resolved, but at least Canon recognizes there is an issue, and they have been in contact with Microsoft, but might not be fixed until mid-January.
I hope the scanners keep working until Microsoft and Canon, and HP and Brother also, finally get it fixed.  I don't know why Microsoft, and Canon, don't post something in big print on their website that says they have this issue!
A New Year's gift from Microsoft: Surprise, your scanners don't work
Hopefully that link above will work, if not this is the complete link:
https://www.msn.com/en-us/lifestyle/shopping/a-new-year-s-gift-from-microsoft-surprise-your-scanners...
I'll hope for good luck for everyone.
Dale...
This issue is sometimes describe relating to USB connections involving the eSCL driver.  Multi-functional devices are also called out as having problems.  My Canon multi-device can run as a USB device, but I have mine configured as an Ethernet network connected device, so I don't quite understand why the discussion has sometimes been characterized only as a USB problem.  I suspect that very large number of users having this problem connect their device to a network rather than an individual PC.  For example, MS described the problem as follows, which seems erroneous to me:
"After installing Windows 11, version 24H2, you might experience issues discovering USB connected devices that support the eSCL (eScanner Communication Language) scan protocol. You might observe that your device does not discover the USB connected peripheral and the device discovery does not complete. This issue primarily affects USB-connected multifunction devices or standalone scanners that support scan functionality and the eSCL protocol."  https://learn.microsoft.com/en-us/windows/release-health/status-windows-11-24H2#3446msgdesc
On December 10, MS described this problem as resolved by KB5048667, which was obviously completely wrong.  It is over 3 weeks since that release and still no solution.
MrNJiwa
I've been hunting for a fix all over the Web.  Kudos, it worked!
DanyChrys
10x - you are the best 🙂
Update: Did get the solution to work on one of the two devices with the issue, additional step needed on the one that did work was to exit the Canon COT software first.  Thanks again!
Dale_1973
As TJ_at_TTA mentioned above, I would try to reboot, and do not try to print or scan, also make sure none of that Canon software has loaded at startup.  If it has you might try to terminate it.  Then try the procedure to reload those drivers.  It could be some software has the drivers loaded so they are in use and cannot be updated.
Hope that works for you.
Thank you, is working.😉
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
