Easy PhotoPrint Editor: How to transfer my items to new computer
Msw
I just upgraded computers.  Loaded Canon Easy PhotoPrint Editor---but can't find a way to transfer My Items from old computer to the new one??  Any ideas on how to do this??
2 ACCEPTED SOLUTIONS
Looks like a Windows PC.  I don't know for sure, but suggest that you check these two locations:
  1. C:\Program Files\Canon\  might be in an Easy Photoprint folder there
  2.  C:\Users\[YOURUSERNAMGOESEHERE]\AppData\Roaming\canon - look around in there.  This is a hidden folder to enable viewing hidden folders in File Explorer via the three dots..., then Options, then the View tab.  You'll see it there.
Plus>> Canon imagePROGRAF PRO-1100 Printer. My photos are edited using no Adobe products.
Thank you for your guidance!!  I was able to find the data, copied the folders to new computer and it appears to be working!!  The location of the data for “Your Items” in Easy-PhotoPrint Editor was
C:\Users\[YOURUSERNAMGOESEHERE]\AppData\Roaming\Canon\Easy-PhotoPrint Editor\WorkData
There is a subfolder for each one of Your Items.
Here’s a screenshot of the folder…
Thank you again SignifDigits!!
8 REPLIES 8
Anonymous
Not applicable
We need necessary information in order to answer your question. What items are you referring to? Printer? Images? If printer what model is it  and what type of computer OS? Windows? Mac?
In Canon EasyPhoto Print you can save items. The items saved can be retrieved under the header Your Items.  Unfortunately I cannot find what directory or file the items are saved into.
I will send a screenshot of the page I am referring to.
Msw
 old computer — these are the items I want to transfer to new computer.
Msw
 New computer!!  No items in folder!!
Yes—Windows 11.  No joy with suggestion 1.  Have found multiple folders from suggestion 2.  Will try to download those and install on new computer.  Will let you know if it works.
SignifDigits
So glad it worked out for you, and thanks for coming back with more specifics.
