Color imageCLASS MF654Cdw network scan to chromebook
jeffmr4
Hello!
  My printer was set up automatically once I used it once via usb.  Now I can print using ipp via the network as well.  I am only able to scan from the printer to my chromebook when the usb cable is connected.  If I try to scan through the network the scan app comes up empty when searching for scanners.
Is there a way I can scan to my chromebook through the network with this printer?  Would using a protocol other than ipp for the printer be a solution?
Thanks.
jeffmr4
I was able to solve this.  I added the networked printer manually.  This was incorrect.  After I deleted the saved printers, connected to the printer via USB automatic setup process happened for the usb printer and then I clicked set up for the mf654Cdw listed in available network printers.
Now it scans to chromebook flawlessly.
2 REPLIES 2
jeffmr4
Hi jeffmr4, If you'd like, feel free to hit that ACCEPT AS SOLUTION button and let all of the community know what worked for you. 😄
Glad everything worked out! 😄
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
