Canon PIXMA TS6400 ...well connected, but 'Offline on an iMac?
Wetstuff
When you turn on Mac's print center ...it show the printer as connected but 'Offline.  It took a while to set up the printer, but the first job it did was spectacular compared to the crappy old B/W printer hat was decades old..
I cannot break the code to get it back online? I would appreciate some help...
9 REPLIES 9
lajopag766
Hello!
If your Mac shows the printer as “Offline” even though it’s connected, restart both devices, check that they’re on the same network or try another cable/port, clear any stuck print jobs, and update drivers. If it still won’t come online, go to System Settings → Printers & Scanners, reset the print system, and re‑add the printer—this usually restores proper communication.
DerrickL
To verify and repair a printer connection use a USB/printer cable, it will make things simpler. You can change to wifi after making a good connection.
Moderator
Moderator
Thanks for joining the conversation, Wetstuff!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. within the PIXMA TS6400 series.  The model number should appear on the front of the unit at the lower right. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
What version of macOS are you using?   Some people have been having problems since the Tahoe 26.3 update. I was having a similar problem after that update - printer showed online and then would show offline if I tried to print to it (I think it has something to do with CUPS), I had to remove the printer from macOS and then reinstall it to get print working again.
Wetstuff
It's a model TS6420a.   ..in 20min of trying various options: it refuses to make a handshake with the iMac (OS - Sequoia 15.73) Reconnect cables..but it will still not show on the Add printer list (there's some old ones I am unable to remove also?)
The info window on the printer wants to talk about the Ooops! paper tray cover in the front cassette ..which is well seated as are the sheets of 8.5x11. I also simply loaded the paper at the rear with also no result.
Should I try a wifi set up?
The printer worked absolutely perfectly on a multi color, 12 pg report a few days ago...   Jim
Is there an error code with that message?   Maybe a paper jam or something?
Wetstuff
....inches an hour:  'No printer selected' was solved by reinserting the cable into the back (into a deep recess) a number of times ..''till I discovered it did not insert 'straight ..it needed a slight angle. Got it!  Jeez...
But... my Mac shows an error: 'Load paper. I use the tray in the bottom front..  That itself is an error...  I adjust the blue guides ..to no avail. I simply does not recognize the this tray.
HOWEVER... when I loaded the rear and pulled out the skeleton tray above the bottom tray... it worked 'as advertised!   ...'rear tray it is!   I love the print quality. I just wish it had been not designed by committee.
Thanks folks for the replies.  Jim/Maryland
msucorey
I have to reset my Pixma TS6400 daily to keep it connected. The router shows it's on the network and none of my other devices lose their connection but the Pixma itself will show the little x next to the wifi signal and not print anything queued from any computer on the network.
This started late 2025. One thing I did to try and resolve was move it over to my 2.4 from 5G but same issue persists.
Haven't found a way to make it get back on other than turning the printer off and on every day.
dpgeller
Sounds possibly like a problem I had (PIXMA TS8320) and continue to have from time to time: the computer (a Mac) says that the printer is offline,.  Apple support gave me the following sequence which does solve the problem everytime it comes up:
1. Power down printer
2. Disconnect the USB
3. Power down the computer
4. Power up the computer
5. Power up the p[rinter
6. Reconnect the USB.
Friends and Family
