10-16-2022 02:52 AM
Hello.
I have the G620 printer. I have a couple of installed ICC profiles (I used them in Photoshop without issues). On Youtube, it looks like the standard Canon driver has a menu for choosing an ICM profile:
but the menu in the driver for my Canon is absent:
Any ideas on how to activate it?
10-16-2022 08:23 AM
It is an issue discussed on the Internet. The Mac version of the printer only uses the Apple AirPrint basic driver with no profile capability.
The Windows version can use ICC profiles but Canon doesn’t provide any.
You could download Red River profiles and try using with similar Canon paper, or just use RR papers.
https://www.redrivercatalog.com/profiles/canon-g620-printer-color-profiles.html
10-16-2022 03:50 PM
Thank You for the answer. I'm sorry, I didn't mention OS: I use win10. And in fact, one of my profiles that can be used in Photoshop is Red River :-).
I aim to utilize my profiles with any other software without Photoshop. For me, the most logical way to do it is to use this option (ICM) in the driver. I have an old spectrophotometer and created one profile for G620 and Canon MP-101 paper. Although results without a profile (using the "matte photo paper" menu in the driver) are acceptable, they are better using my profile: the black is more black, the yellow more yellow without adding red, and all colors are a little richer.
Can I install any other old version of the driver to enable the ICM option?
10-16-2022 04:57 PM
I have a Pro-100. I never use the ICM option. Even for Caon profiles I select Manual->Setting->None and always select the profile in the application. I never have the printer manage color.
Maybe you can try that.
10-17-2022 12:21 AM
Thank You. Yes, for photoshop, I use this way ('None' in the driver and my profile in PS). But PS looks too overwhelming way for simple photo printing. In the case of availability profile management in the driver, the choice of software is endless.
05-10-2026 05:36 PM
Im looking at buying this same printer and wondering if you figured out your situation? I am looking for an all-in-one printer that can handle paper/color management like a pro printer. I know from long experience witha Canon Pro-100 the ideal way to setup printing from PS is to go to "Manual Color Management", and under the "Matching" to select "None". Then in the Photoshop print window to select "Photoshop Manages Colors" and then select the Paper ICC profile. The issue I'm trying to get answered, is like my Pro-100 I can select specific profiles in that last step, ala, "Canon Pro-100 Semigloss/ProLuster/ProPLatinum/PremiumMatte" etc etc, however on my existing all-in-one, it only has a standard "Canon IJ Profile 2015".. and no options to install ICC profiles (Its a TR7620).
Does this Canon G620 have included profiles for each paper type, or is it a generic? Have you found any ICC profiles you can install that produce good results? I need that ICC profile handling of a Pro-100 like printer, but in an all-in-one like this G620 if it allows for it.
Appreciate the feedback!
