Canon PIXMA MG3620 connection failed after finding printer
spungie
I get to the point where my computer finds the printer on the network but then it says "connection failed. une another method for setup. follow the on-screen instructions." What could be causing this to happen.
We know you have a MG3620..
But we don't know what operating system you have or how the printer is connected and to what?
So my advice might not be 100% appicable to your situation or environment?
Disable IPv6
Check your Firewall settings
If you are using any 3rd party antivirus, this might cause a communication issue with the device during install
Are you using the correct installer package for your operating system
Test with another USB cable
6 REPLIES 6
Disable IPv6
Can you tell me what the issue was?
spungie
Sure, disabling IPv6 worked.
Oh, also, Windows 10 is the operating system.
Pegasusa
I disabled Norton Firewall and connection failed again.  Using Windows 10.  Will see what happens using USB
I disabled IPv6, disabled Norton Firewall and connection still fails.  Shouldn’t I be required to enter the WiFi password?  That does not occur
How does one disable a PIXMA (TS3320) printer's IPv6 if nothing will connect to it?  [Canon PRINT on my phone says the printer is offline, win-ts3300-1_5-n_mcd.exe (which calls itself "Master Setup" in Windows 10 Task Manager) reports "connection failed", etc., etc.]  Can I disable IPv6 at the printer console?
