03-16-2019 11:37 AM
Hi all
I'm in the process of connecting my new printer to my WiFi, laptop, etc.
I've managed to connect the printer to the WiFi fine, but can't get the laptop to find the printer on the network to allow me to print. When I run the install software, it says it's finished but then fails to detect the printer at the end of the process.
Incidentally the Plusnet Hub Manager does show the printer as being connected to the network, but calls it 'Unknown-74-bf-c0-38-ae-5b' rather than anything more meaningful. Don't know if that's connected.
Any ideas? Am I missing something obvious? Any ideas welcome.
Thanks in advance
Martin
03-20-2019 05:14 PM
Not sure anyone still listening, but I solved this in my case at least. Related to a problem with the router using dual bandwidths. I'll give details if anyone needs.
03-20-2019 05:14 PM
03-21-2019 02:07 PM
03-21-2019 03:30 PM
Hi msmwinter,
Is your MG5520 not detected when trying to print or are you trying to connect the printer to a new or existing network?
03-21-2019 04:24 PM
Just to expand upon my own solution, I found that when I linked my printer and my laptop to my mobile phone's personal WiFi hotspot, on mobile internet, the printer worked fine. From that, figured there must be a problem with the router, not the laptop or the printer. Backed this up by printing succesfully via USB - again no router involved. Worth a check.
If that does happen, what I found was that my router runs at 2 different bandwidths - either 2.4G or 5G. I think the 2 devices were both linked to the router but on different bandwidths. I went into the router settings via the hub homepage and changed the bandwidth settings to manual. I then manually set both devices to the 2.4G bandwidth and the printer immediately started working over the WiFi.
I am absolutely no expert so it's possible something I did sparked something else to make things happy again, but as I said it's worth a try. Good luck.
