02-07-2023 12:21 PM
I tried to install the driver on my laptop (Windows11). I downloaded the software but I couldn't install them. Error message said,
WinZip Self-Extractor header corrupt. Possible cause; bad disk or file transfer error
02-07-2023 02:12 PM
Delete the file and try re-downloading. The error indicates a file that is incomplete, corrupt or cannot be read.
02-07-2023 07:05 PM - edited 02-07-2023 07:07 PM
Right-click on the newly downloaded file. Select rename from the context menu. Append the file extension name from .exe to .zip
Example (oringinal)
rumiringo.exe
to
rumiringo.zip
Note, if you don't see the full name of the file with its extension, you will need to enable this in the view options where you downloaded the file (probably) Downloads.
Select View Menu, then check "File Name Extension"
After the box is checked, you will see the extension and can modify (change) it to .zip.
Now right-click the file and select "Extract All" from the context menu. This will manually unpack the file. Now run set up.
02-07-2023 02:12 PM
02-07-2023 05:01 PM
I did delete and re-download but still cannot install driver software. Same error appeared. Please help!
Example (oringinal)
rumiringo.exe
to
rumiringo.zip
02-07-2023 11:01 PM
It worked out. Thank you🙂
02-07-2023 11:22 PM
Very glad to hear. 👍
06-05-2023 09:17 PM
I have the same issue and this allowed me to go into the application but during the setup the same message pops up and then it says it failed to complete the instalation help please
