11-05-2024 07:13 PM
Proper software downloaded Printer has long history of faithful printing. Connect is USB printer cable. Test page will not print. Suggestions? Please.
11-05-2024 10:04 PM - edited 11-05-2024 10:05 PM
For USB devices, not just printers, its best to install the drivers first before connecting a device. Or not doing so until prompted. If you have 3rd party anti-virus installed, this could also cause issues. The printer should be connected directly to the computer, and not to a hub or adapter.
If you connected the device before running the installer, I would remove the printer from Printers and Scanners, uninstall the drivers, restart your system and run the installer again and not connect the device until prompted to do so.
11-06-2024 01:05 AM
Rick:
Your counsel was spot on. I now have an operating printer.
Thank you and bless you.
-bob
11-06-2024 04:01 PM
Thank you for your reply and feedback.👍
